Carvin_Marvin
Sep 04, 2019Explorer
Ford Questions
Just acquired a 2014 31' Newmar. How do I remove the hub caps on 19.5 tires? How does the "Tow Mode" function. Haven't got the books. Thanks in advance for assistance.
ferndaleflyer wrote:
Sorry Bruce Brown if I have misunderstood Ford and my transmission rebuilder about these transmissions in all these Fords I have owned over the past 40 years or so. Maybe I am just old and my memory is fading, but it worked like that this morning.
mleekamp wrote:
jy is correct...but allow me to add to that. Tow/Haul not only changes the shift points of the transmission, allowing it to hold a gear longer for towing or hilly climbs, it also functions as a "transmission brake" when going downhill. jy mentions this as well.
I recommend going to Ford website and you can download a PDF of the chassis owners manual, which should be a must for a chassis you are not familiar with.
Horsedoc wrote:
Depends on the type wheel, but if the caps look like chrome lug nuts (about 8 of them) there will be two that hold the hubcap on. Look carefully to determine which is fake and which holds the caps on. Somewhere in your rig, there is likely a T handle tool with a socket fits these "nuts". Carefully loosen the two 'real' nuts and the cap should come off. Good news is these two are 180 degrees from each other.
Don't know about hub caps but tow mode just keeps it out of over drive and decreases fuel mileage.
