PsnRebel's avatar
PsnRebel
General Quietpac 75D Stopped Running, won’t start
So we bought a 2005 Mandalay Presidio 39b about 2 years ago. We are fortunate enough to have a Generac Quietpac 75d installed. Around 800 hours.
Last time driving back east the generator suddenly died. It cranks, actually starts but once you let off the start button it dies. It has fuel. Coolant is filled to specs.
Using the flow chart in the service manual I think it’s the control board. Just one test I can’t do. It requires removing the grey plug harness that goes to the control board. I don’t know how it detaches. I can’t see because of framerail is in the way. Anyone with experience changing out the control board ? It appears to be held in place by 4 white plastic posts that have tabs that need to be pressed in , in order to pull the board. How do I collapse those white pins in order to remove board ?
Is my best bet to loosen generator mounting bolts and pulling it forward about a foot ? Any advice would be appreciated.
Thanks in advance. I’m located near Augusta GA if anyone knows of a competent service place for this amazing piece of equipment (sarcastic).
