supercub's avatar
supercub
Glue to use on Corian?? (Additional Info)
My corian table top is fastened to the wall by a metal channel with 1/4 inch pins that the edge of the table fit into. Trouble is, the pins have come loose. What can I use to secure the edge of the table with these pins? Would epoxy work? do they make some special type of adhesion for corian? Thanks
NEW INFO: Well before I got home, the table top edge support fell off and the table top fell to the carpet.......I think I'm lucky it didn't break. Anyway, they have a medal strip that attaches to the edge of the corian. Screws go thru the medal strip and into medal anchors. The anchors all pulled out......so I need to glued these into the corian.........so what I'll be glueing is Medal anchors into corian. Suggestions? Thanks
Brian
  • Many epoxies don't bond well to many plastics. Since Corian is more or less a mixture of a plastic base with some filler added, it probably wouldn't bond too well with standard epoxy.
    There are specialized solid surface countertop adhesives available...for a price.
    If it were my tabletop, I might be tempted to try adding some mechanical fasteners such as screws through an additional bracket made from e.g. an aluminum angle extrusion on the underside.
