pandorasbox65's avatar
Apr 19, 2016
Help! Replacing Coleman ( wire thermostat
I am replacing and old Coleman analog thermostat with a Honeywell digital. My old Thermostat has 9 wires, the new one doesn't. I have no spots for the Y1 & Y2 wires. What are those for and do I need them connected? I have also seen conflicting information on the Red Wire and Blue(ground) wire placements. Some say don't use red wire, as it is only to power the old thermostat and the new one takes batteries and to put the ground in the R spot. I watched many videos and read many blogs on the subject, seemed pretty straight forward. Now that I have it all apart and rewired, I am not sure if I have it right. Also, to I set the new thermostat on gas or electric?
  • It can be tricky. You have to compare both schematics.
    First of all did you verify the new thermostat is compatible with your system?
    Some are and some not.
