Cinikal's avatar
Cinikal
Help with 1998 Pace Arrow Vision Transfer switch
Hello all, My buddy has a Pace Arrow Vision that the transfer switch apparently has failed. I have been told it was under the refrigerator but all see under there is 2 boxes. One has a fan attached to it and it seems to be a power inverter. The other box is marked "Transfer Delay Relay part# 00-00331-000 which is obsolete and has been replaced by some other part# 00-00568-000. But this is rated at 15 amps. I would imagine that the tranfer switch would be of a different higher rating am I mistaken and that is the actual transfer switch. Thank you for any help.
  • Your second photo is in deed the converter.
    Check with your buddy to see if he has an inverter.
    Looks like he has no transfer switch. I hate the generic block diagrams from manufacturers.
  • So I am waiting on a response from owner as to what the shore power amperage rating is. I think you are correct Doug, I am adding an album of pics I just made. Enblethen, I pulled some drawers and opened hatches but I just do not see it! It can't be that complicated?!?!:?
    https://imgur.com/a/ezJ55c0
    Here is what is under the fridge!
  • Odds are the Transfer Box you see is NOT the Main Transfer box for the Incoming 120 volts. You need to clarify. Does your year model have 30 amp or 50 amp Shore Power? The reason I ask is, when you see a 15/20 amp interior Transfer box like you have found, It is usually connected to the System that allows Front and Rear AC operation on Shore Power when you only have a 30 amp RV. Doug
  • so under the fridge is the breaker panel. When I remove the breaker panel I see the transfer delay relay in a metal box and the converter. When I get home I will start pulling drawers.
  • Those generic drawings don't help.
    Image definitely indicates the one is for the A/C only.
    Where is power distribution center?
    I can access mine by removing draws in hallway.
  • These that are in Orange are under the fridge. there is nothing else that I an see!
    https://imgur.com/a/Inz8L21
  • My older Pace has it right behind the power center next to the converter.
  • Numbers you posted appear to be the control for the transfer switch. It appears to be for a single appliance, like the A/C
    time delay
