Gjac wrote:
....... I would look carefully at the CCC of any MH's you are considering. This info is sometimes hard to find on the MFG web sites. From what I have seen the sprinter models don't have as much as the gas models. Also I would try to find a model with the large pass thru storage bay in the rear, going from a Class A to a small C storage will be a lot less.
Good points! I'm not sure how to figure the CCC, but if I combine the listed axle weights at 12,130lbs, and subtract the GVWR of 10,858lbs, I get 1,272lbs left. So I would make a guess that with a full tank of fuel at 29 gallons at roughly 7lbs/gal being 203lbs, that leaves just north of 1,000lbs for people and cargo/food/water/beverage, etc. IS that the right way?
