timmac's avatar
timmac
How Much Tire Air Pressure When Carring More Weight ?
I have upgraded to G rated tires on my motorhome and at max pressure it will carry 4575 lbs per tire {dual} at 110 psi, but when I weighted my motorhome my rear axel weight was 14,400 lbs, {fully loaded and tonged weight from trailer} so I run at 90 psi in rear tires but how do I know if I am using enough air pressure.
Is there a chart that says what weight at what pressure, 110 psi would be just to hard.
Also the tires have no minimum pressure on tires other than label inside motorhome that's says 80 psi but that was for the F rated tires from factory.
