Ka_Ron's avatar
Ka_Ron
Hydraulic fluid
We have a 1998 Fleetwood Southwind with a super slide and there is a reservoir under the slide that had fluid in it.
Over time the fluid has slowly disappear from the reservoir.
No idea where it went as there is no marks on the concrete under the motor home.
Anyway, I am just wondering what is the best fluid to replace the fluid that was in the reservoir.
The slide still works well, but I am sure it is just a matter of time until it will not, if the fluid gets too low.
Thanks
  • Find out who makes it. Should be a website with info and/or a phone number.
    g'luck!
  • Old-Biscuit wrote:
    Typically......ATF (tranny fluid) but you need to check manual
    Hydraulic fluid doesn't evaporate.......so if level is going down you have a leak.
    At a fitting, piston seal, reservoir gasket, someplace.
    And reservoir should only have fluid added/topped off when slide is retracted (in).
    Thanks.
    We will take it in and get it checked
  • Typically......ATF (tranny fluid) but you need to check manual
