FuzzyKnight wrote:
Fire up
Look on the dash. There is a switch labeled Utility lights. This is the one that puts power to the compartment lights.
Or at least it does on our 94 Pace Arrow.
Hey FuzzyKnight,
Santee huh? You're right down the street from us. Cool. Anyway, I was only mentioning that the last coach we had, had a "Utility" light on the drivers side that did have the controlling switch on the dash but, the Utility light on our present coach, the Itasca, is contolled by a switch in either the water/dump compartment or, the electrical hookup compartment. And, the compartment lights on the Bounder were "single switch" controlled, just inside the door. Whereas the compartment lights in our Itasca are individually controlled by opening each compartment door separately. I like that system way better than the single switch one.
Scott
