JimM68's avatar
JimM68
Monaco interlocks?
Our Monaco, a 2008 Knight, has a whole bunch of "safety interlocks"...
The jacks are interlocked to the parking brake, which is good and I like it.
The slideouts and awnings are interlocked to the ignition. I don't like this a bit. According to the manual, the coach must be up on it's suspension when extending or retracting the slides (Backwards I know, but it's a Monaco thing, simply accepted as fact for this discussion)so my Leaving the campsite routine includes:
Starting the diesel and waiting for the air pressure to come up.
Retracting the jacks.
Shutting down the diesel
retracting the slides.
Firing her back up and rolling down the road.
Now I'm thinking, things would just be so much easier and make so much sense, if the slideouts and awnings were interlocked to the parking brake.
And I'm guessing this would be a simple matter of moving one wire.
But which wire?
And move it where?
I know this has been done, I probably shoulda saved it when I saw it. but regardless, Monaco or HR DP owners, whatcha got?
  • Personally, I don't see the problem. I've been doing it that way for years. Only takes a minute to do. I start the coach, disconnect the water supply and put it away, waiting for the pop off to tell me the system is aired up. Turn off ignition, pull in slides, disconnect the electrical supply, do my walk around and I'm gone. :h....Dennis
  • Interesting, because my '07 Itaska Horizon manual specifically tells me to retract the slides with the engine running.
    But I don't have all that fancy interlocking electronic stuff. Good luck, I could see how that would be a PITA.
