- MackteeExplorerBought mine at Avondale CW and happy with price and product. Macktee
- slemnahExplorerWhere are youguys getting your LED light strips?
Steve - gvisnicExplorerWhen I installed mine, I opted for an RF control versus an IR controller. This uses radio frequency versus infra red that you have to point directly to the controller. I was able to drill a hole from the outside into a cabinet, used a plastic piece like they use for running cable into the house, sealed with silicone well, and was able to tap into a 12v wire to a map light over the passenger chair. I also wired in an on off switch that lights up, lets me know the circuit is on.
- MeffrigExplorer
Executive wrote:
Are you asking about the red white and blue colored rope lights or the multi colored ones that flash off and on changing colors...?////Dennis
Multi colored LED's that change colors. CW sells the Dometic brand but the kits are high dollar compared to some other brands. I don't mind paying CW's price if they are really worth it. - Executive45Explorer IIIAre you asking about the red white and blue colored rope lights or the multi colored ones that flash off and on changing colors...?////Dennis
- Playtime_IIExplorerdrill a small hole for the wires and seal with 3m 4200 or 5200. I opted to go a different route. I ran the control wires from outside (under the end of the LED strip into the overhead cabinet. Inside the cabinet the wires connect to the power adapter (110v to 12v). I just open the cabinet and pull the 110v plug out and into the receptacle on the underside of the cabinet. I did not want the LEDs on 12v. Too many things already drawing power when "off".
I taped the remote sensor to the glass so I can control from the outside. I tried inside but there are some codes that also control the TV. - IvylogExplorer IIINot sure an electric awning is any help as mine is 120V and those with a motor in the tube only have power when the motor is running. I had to drill a small hole through the side to get power from the 12V lights inside. With a normal roll up awning I would probably mount the light strip just under the awning when it is rolled up so you can still use it with the awning in. I have to put my awning out a little bit to use mine so maybe I should have mounted the light strip on the outside bottom of the channel, not inside.
- How would one add a LED strip if they do not have an awning rail to run the wires behind ? I have seen a lot of RV's with the lights and they all had an electric awning.. Mine does not
- IvylogExplorer IIII added this strip LED to my awning and a 3' strip over the door for extra outside lighting. Not a fan of multi color outside lights. :E
- MackteeExplorer
paulcardoza wrote:
I chose the warm white style, instead of the multi-color. Spend a bit extra and get the brightest you can find, which is also dimmable. Then you can adjust them as the situation requires when outside....
Our coach has a Girard Awning, so I stuck them underneath the edge alonf the wall of the coach. Then I ran the power cord in behind the entry light and wired it inside the coach, behind the inverter control panel. The remote works from outside or inside, perfectly.
I can have the lights very bright for playing cards, reading, etc, and can turn them way down for "mood lighting" most other times.
X2 what Paul said and make sure they are the cool white. Much better lighting. And having the remote, that you do not have to point right at it is invaluable. These are a little more expensive and come in 39" lengths, but well worth it. Macktee
38,707 PostsLatest Activity: Feb 20, 2025
