Ivylog
Mar 01, 2014Explorer III
Need help Norcold 1200 with a Amish cooling unit
Unit is not cooling well, 6-10 degrees on back wall of the freezer and fins above 34. By disconnecting the thermistor it will freeze things in the refer section in less than 20 hours. Had the correct new thermistor so installed it. Unit goes back to not cooling well with the above poor temps. In less than 8 hours with the thermistor disconnected it will be 0 or less in the freezer and the fins 28 or less in the refer section. Temp set on 9 and manually running the outside fans makes no difference. It's 75 or less out side and unit is in the shade. Any suggestions of what to do next is appreciated in advance. Thanks Dick B
PM sent to Doug Rainer and serial # 1156821
