Jerry_Amerson1's avatar
Aug 23, 2015
Onan 4000 Generator Problem
Hey all,
I recently posted that the Onan 4000 on my Fleetwood was roaming and would only stay running if I wedged the Governor open, but that is not the case. I went out today to check the adjustment you all told me about and realized that what I was wedging wide open was the CHOKE!!
This puts a whole different twist on things and tells me that there is a fuel delivery problem. My first thought is to replace the fuel filter and I got the seafoam to run through it as well. I'm testing it without any load so if any of you have other suggestions I welcome hearing them. I will have to order the fuel filter so it will be next week before I get it replaced.
Any help is always greatly appreciated.
Thanks,
Jake
  • You are right..I'm having to keep the butterfly closed in order to get more fuel to the engine. I will get the fuel filter ordered and see about getting some of that other cleaner.
    Thanks
  • SeaFoam is a great marketing company.
    Their product is good at what it was originally designed for: Marine Fuel Stabilizer. It is not so great for all of the other "snake oil" claims that they make for it.
    Berryman's B12 Chemtool is a MUCH better cleaner.
    At 2X the recommended dose, it sometimes works miracles.
    Are you sure you were propping the choke "open" and not CLOSED ??
    I have the same unit....or very similar.....and got a new carb installed for about $285. Additives and a manual cleaning by the previous owner just didn't get it.
    I was amazed to find that mine did not have a fuel filter; one was added.
  • Replace the fuel filter first. A clogged filter can cause a lot of problems.
    Plus, then you will know when it was changed.
  • Sounds to me like deposits in the carburetor. Maybe the Seafoam will work but more likely a disassembly and cleaning is in order.
