Effy wrote:
Just curious, I've been in situations where my tires were off the ground and never had an issue. I mean where is the RV going to go? It's still on the ground via the jacks. The jacks have a footprint about equivalent to a tire. The jacks would have to laterally collapse and then it would drop to the tires anyway. I seriously doubt there is a risk of it skiing down a hill on the jacks. And they will only extend so far thus inhibiting you being on a step enough incline for an issue to occur. Sorry I just never understood the "tires have to be on the ground" thinking. I see lots of folks at CGs all the time with tires off the ground. I've never seen an issue where it took off because of it. Not trying to be crass, I've just never seen or heard of an actual issue. If you use your jacks, and then add boards under your tires, what's the point of the jacks? You might as well just have leveling boards and drive up on them.
It depends on the type jacks. If you have HWH kick down jacks and you lift the weight of the motorhome off the tires, the motor home will then shift FORWARD as the jacks are forced to flip on the Kick down pivot point. If the slope is great enough, if you lift the tires off the ground, the motorhome CAN slide that downward slope a little bit and then the jack pistons usually bend a little. Then you cannot get them fully up. You last statement is kind of lame. Which is easier--
1. Putting extra boards UNDER the jacks to get more lift?
2. Or getting out and adding a slope to then attempt to drive onto a bunch of boards?
I think the answer is obvious. BUT, you NEVER lift tires off the ground. ALWAYS install support boards under the tires(front) if you do that. The reason is, IF one of those jacks developes a leak or starts a retract, that corner will then come down and put a stress and possibly harm the frame or pop or crack a windshield if in front. With boards under the tires the boards will support that corner if a jack fails. Doug
