ncrowley
Jul 26, 2014Explorer II
Power Wahser to Clean Rear Radiator
I would like to clean my rear radiator more often but I have been told (by two different repair shops) that I need heated water or steam and at least 2000 psi. You spray straight on so the fins do not bend. I was told I needed that to get through the radiator clear to the back. I looked and I cannot find a way to access the back of the radiator. I have a Cat C7 350 hp. The problem is the power washers that heat the water cost a LOT of money - over $2K. However, it gets expensive to take it in to be cleaned. Are there any other choices?
