Problem figured out - not solved yet, but know why!
The Hazard 4-Way Flashers Light Switch (Off/On) is faulty. When I push the switch to "On", nothing happens. But when I "lean" the switch slightly to the left, the Hazard 4-Way Flashers start flashing audibly and visually on the dash.
The switch body is recessed beneath a two-piece protective cover. I have to remove the top half of the cover to get to the switch body. The top half of the cover encircles the ignition switch and cannot be lifted until I remove the top part of the switch. The top part of the ignition switch is what you twist with your thumb and trigger finger when you are turning the key.
How do I get that switch apart?
Thanks.
