kdk
Nov 20, 2018Explorer
Roadmaster auxillary toad brake inJeep Wrangler
I have a Roadmaster 9001 auxiliary brake system which is a pneumatic cylinder attached to the brake pedal and a bracket under seat. Worked great in my Buick Lacross. Changed toads to 2015 Jeep wrangler 4 dr. Now the Jeep's brakes are applying to hard leaving the wheels covered in brake dust. Called Roadmaster and was told to install a pressure regulator in line between said cylinder and the brake away reservoir.
I believe this is the proper solution. Has anyone done this and if you have what pressure did you set the regulator to? If I have a good starting point I will fine tune it from there.
Thanks in advance and have a blessed Thanks Giving; Keith
