barmcd
Nov 03, 2015Explorer
Roof Construction--Pros and Cons?
Up to this point we've only owned a trailer and 5th wheel and both had a rubber roof. We didn't have problems with either RV and maintenance consisted of replacing the caulking every 5 years.
I notice motorhomes come with aluminum, fiberglass and rubber roofs. I understand the construction of a rubber roof and assume fiberglass is similar in that its either one sheet or several sheets bonded together to make a solid roof.
What about aluminum? It's not one large sheet of aluminum is it? I assume its several sheets bonded together somehow. How are the seams between the sheets sealed.
More importantly, what type of maintenance is required on a fiberglass or aluminum roof?
