- s_N_sExplorerThere are some video's out there that show the technique painting the hull of a boat. When finished you wouldn't even know it was done that way had you not been told. A friend of mine did his boat, quite amazing of the results. It looked like it had been sprayed on. Now he didn't use Rustoleum but a boat paint instead with a foam roller. Can't remember the name of the paint though.
- dewey02Explorer IIEven Earl Scheib didn't use a paint roller! :)
- azdryheatExplorerGuess this is why some parks have the ten year old rule. lol
- htownersExplorer$50 Paint Job
6 to 10 coats with wet sanding in between, no way for me.
There are a bunch of videos out there too. - DrewEExplorer IIA foam roller and Rustoleum can actually make for a surprisingly good finish if done carefully. A little bit of googling will give details. Most people seem to thin it down a good bit with mineral spirits. Assuming it sticks properly to the existing finish, which I don't know if it would, I really don't think it would lower the value of the RV at all if done nicely. You don't have to tell any potential buyer you painted it in Rustoleum with a roller.
If I were attempting this, I would consider getting catalyst (and maybe paint) from Tractor Supply or wherever else it's sold. That makes for a harder finish. - Dale_TravelingExplorer III rattle can repainted the sun stroked black graphics with Rust-oleum. Lasted two years before the color started fading and changing color tone. Repainted again this spring with real automotive paint. Paint was $125 and the sprayer was $50. Roller paint, well hope you like the coach.
- westernrvparkowExplorerHow much is your RV worth? Subtract $1000.00 from that figure and you will get a rough approximation for how much you will lose if you paint your RV with a paint roller.
- Tyler0215ExplorerWhat?
38,763 PostsLatest Activity: Dec 13, 2025
