We have a Sealand traveler China toilet. Had the floor flange seal replaced, hand held hose replaced,water valve,and flushing pedal replaced. It still leaks from the bottom. Any ideas.? Getting ex...
I had the same problem and finally figured it out. Turned out to be the flange was cracked. I found an exact fit at Lowes and cut the old one out with a Dremel tool and the new one fit right into the pipe going into the holding tank. Hope this helps. Busyguy
