Sandra's avatar
Sandra
Sealand toliet
We have a Sealand traveler China toilet.
Had the floor flange seal replaced, hand held hose replaced,water valve,and flushing pedal replaced. It still leaks from the bottom.
Any ideas.?
Getting expensive.
  • Skylark wrote:
    Thanks old biscuit for the manual link, been using sealed toilet for ten years and did not know to pull up the lever to add water to bowl. I still have not learned how to used the toilet spray nozzle, any ideas?
    Sprayer only has water pressure/flow when flush pedal is pushed down.
  • Thanks old biscuit for the manual link, been using sealed toilet for ten years and did not know to pull up the lever to add water to bowl. I still have not learned how to used the toilet spray nozzle, any ideas?
  • I had the same problem and finally figured it out. Turned out to be the flange was cracked. I found an exact fit at Lowes and cut the old one out with a Dremel tool and the new one fit right into the pipe going into the holding tank.
    Hope this helps.
    Busyguy
