Belgique
Sep 10, 2013Explorer
Table re-cover
The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
Johno02 wrote:
The most dangerous thing in an RV is a DW that gets a case of boredom.
Belgique wrote:
Lorraine: not sure. It is a very thin plastic like material that probably was put on with contact cement and heat? It fits tight with no wrinkles on the curves. It is just the edges going bad...for now. The table has curves on the aisle side and the edges are curved to the table top.
Clay L wrote:
You can use contact cement to repair it. Although as I understand it manufacturers have to use water based cement but individuals don't.
I use solvent based and it seems to hold much much better. I haven't tried to buy quart cans so don't know if larger amounts are available but tubes are.
