TB_KE's avatar
TB_KE
Thor Tuscany - water is hot everywhere but the shower!
We have a new (8 months old) 2019 Tuscany 45' Class A - We are new to camping period and have learned a ton - but this trip has been a long one with cold showers. The water in all the faucets is super hot - yet when we try to shower it's basically room temp turned all the way to hot. We've looked at everything we can figure to look at and it's almost like there is some regulator or something. we have Aqua hot and were promised endless hot showers :) Any suggestions or help would be greatly appreciated.
TB & KE the Newbies
  • Dick_B wrote:
    Not sure this matters but is there an outside shower?
    Yes there is The only thing we've ever used it for is to rinse the sewer hose AND my husband noticed the knob are backward from normal aka hot to the right and cold to the left. Maybe???
  • I have no idea what kind of mixing valve you have on your shower but I'd suspect some debris in the line leading to the how water side. The easiest way I know of to make sure would be to drain the pressure on your system and remove the valve for inspection. Once the valve is removed, you could put a plug in the cold water line and a hose on the hot water side and pressurize the system and see what kind of flow is available to the shower. If you get a full stream with plenty of pressure, the problem is in the mixing valve and it would need to be backflushed, disassembled for inspection or replaced.
