ScottG
Mar 30, 2017Nomad
The adjusting collar looks loose. (Tie rod end stays almost still but the adjuster moves). Center the rotation and tighten down the collar on the passenger side. If the drivers side is the same it needs to be tightened as well. The tie rod "heads" should sit in the middle of their movement.
