DAS26miles
Mar 30, 2017Explorer II
ScottG wrote:
The adjusting collar looks loose. (Tie rod end stays almost still but the adjuster moves). Center the rotation and tighten down the collar on the passenger side. If the drivers side is the same it needs to be tightened as well. The tie rod "heads" should sit in the middle of their movement.
The rotation is at the tie rod ends and not very visible in the video. Checked another E450 and the rotation was a 1/3 of what I have. The adjuster is tight. Nothing wrong with the Bilstein steering stabilizer except that the dust cover sleeve has slipped and crunched. Easily refastened.
