Effy
Mar 05, 2014Explorer II
tire pressure - again
I know, I know, this has been brought back more times than the living dead. My question is very simple. My tires on my 16k# coach are Goodyear g670s. I like them. The sticker inside says to run them at 83 psi. And I do. But the ride is rough. Smooth on smooth roads but hit a pothole or concrete road and the feedback will rattle your teeth. My coach is light and in talking with my dealer he says I can run as low as 75 psi to soften it up. Looking at Goodyear’s rating table, there is a marginal difference in weight at the wheel between 85 and 75 PSI. Talking 300 lbs. Now I have never weighed all 4 corners and doubt I ever will. I mean a very small change in weight at a corner is so small, it might be attributed to filling up with gas or emptying the tanks, to loading the refer or a cooler. Not to mention shifted weight. Heck even a person moving around. That’s a constant in RV’s. So my question, to soften the ride, can one safely reduce the psi 5-8 ? Now I will say the gap between my duals is about 1.5”. It would scare me a bit to lower this too much as I know I don’t want these to rub. I know I’ll get a ton of blasts about how unsafe all this is without weighing and breaking out an abacus. But I can tell you I will run different psi in my truck depending if I am hauling, going on a trip etc. Changing Psi 5-8 really does not seem to be a big deal based on road feel. I mean I have to imagine it changes that much on its own going from hot to cold climates, low to high elevations etc. Blast away.
