I finally got my Onan generator running and it puts out good voltage, 122. The problem is, it doesn't seem to connect to the RV panel. When I plug in the RV everything works fine, but the generator do...
Don't know for sure about your RV, but many have a plug outlet connected to the generator. In order for the generator to be used, you have to plug the shore power cord into the generator outlet. It is a crude way of doing a transfer without a transfer switch but accomplishes the same thing. Typically the outlet is located somewhere in the power cord compartment.
