I finally got my Onan generator running and it puts out good voltage, 122. The problem is, it doesn't seem to connect to the RV panel. When I plug in the RV everything works fine, but the generator do...
FYI, in the event that you DO have an xfer switch, in my '94 Bounder, it was BEHIND the fuse/circuit breaker panel above the dinette. Took me much internet searching to find that thing. Weird. There's a lot of them that are behind the circuit breaker panel in the master bed frame too.
Also, most gensets I'm aware of have circuit breakers right on the generator and they need to be closed to supply the RV.
