Geocritter's avatar
Geocritter
Unexpected engine failure (shut down) 1994 Ford 460 V8
This is a question for you folks with older (1994 vintage) Ford 460 V8’s. I had a strange event happen with my rig on my trip from Huachuca City AZ to Fresno CA. I was traveling north on I-5 from LA and just past Bakersfield my engine lost power and shut down. It’s done this once before on a long grade outside of Benson AZ. At the time I replaced the fuel filter and I also back-flushed a bunch of rust from my old filter, so I wrote the event off as a partially clogged fuel filter. This time I’d just gone over 4,148’ Tejon Pass an hour earlier with no problems and I was cruising along nicely on a flat stretch of I-5 with my cruise control set at 60mph when I began losing power. I quickly shut off the cruise control and worked the throttle. The engine started running smoothly again, but almost as quickly began once again to lose power. The engine finally shut down completely and I coasted off the highway. I sat for awhile and tried to start the engine, it barely turned over which was odd because before I’d left AZ I’d installed a brand new group 65 750 amp battery. As a test I beeped the car horn, which draws a surprising amount of amperage, and it beeped loudly. The entire trip my amp gauge was showing it to be charging. Anyhow, after sitting for 20 minutes I gave the engine one last crank and the engine fired up and ran great the last 100 miles to my destination.
So when I started this journey 650 miles before the problem in question I had:
I installed a new group 65 750 amp battery and a new battery cable. Up until this point the engine had cranked strongly. Within the past year I’d replaced the starter.
Within the past 1,500 miles I replaced the spark plugs, air cleaner, changed the oil and filter.
Within the last 650 miles I’d replaced the fuel filter.
The engine typically runs very well, the only consistent problem I’ve noticed is an occasional slight hesitation upon acceleration, and that usually occurs when the engine is cold. It’s such a minor thing that I haven’t given it much thought.
While I’ve owned and driven the machine it’s never over heated, it’s always shown excellent oil pressure, and the amp gauge always shows a slight charge while running (like you’d expect).
I’m a driver who’s normally well aware of what going on with my engine and this engine shut down came with no warning that I was aware of. Does anyone have any ideas what caused my engine to shut down like it did?
Steve
PS I'd suspect vapor lock but (1) I have fuel injection (2) the day before I'd driven under similar conditions through AZ in 100 degree heat.
