enblethen
Jun 28, 2015Nomad
Your rig may have a battery disconnect which would not allow battery(ies) to work.
The 120 volt system should be powering a converter which charges the battery system. Check to make sure converter is operating and breakers are on. Check for main battery and converter fuses in the 12 volt DC power distribution panel. These fuses are normally adjacent to the 120 volt circuit breakers behind small metal plate.
Disconnect the bad battery and see if system operates. Look for make and model of the converter.
38,763 PostsLatest Activity: Dec 05, 2025
