waroland wrote:
Just wondering about head space as you enter ClassAGeek.
That's a good question. In our front engine MH, the doghouse is right below the TV. It is pretty hard to get anywhere near it while standing or sitting. The windshield is large enough that the view is generally unobstructed too.
If your entry door is at the front, you might have more concerns about clearance. But you are also climbing up a few stairs so you will likely need to measure more carefully than I did. As I mentioned before, 16:9 flats screens don't gain much vertical height as they get larger.
I think many MH's could install bigger TV's. I suspect the manufacturers don't want to cough up the extra $500 or so. Too bad. I find this setup beats squinting like I used to do with a 32" LCD.
