ClassAGeek's avatar
ClassAGeek
Yet Another TV Conversion
Like many MH owners I am happy with my recent LCD TV upgrade. But unlike most, it took me 3 upgrades to be completely satisfied. Here are some of my experiences.
Upgrade #1 in 2009
Let's start with the hole left by original 23" CRT:
The box that framed the original TV is 6 gauge steel. It will hold just about anything. With that in mind, I built a mounting frame out of mainly 2x4 pine to secure the new LCD TV:
I thought getting a new TV the same width as the original made sense. As such, I settled on a 32" LCD :
There were two problems with this upgrade:
1. The new LCD TV had the same width as the original but a wider aspect ratio meaning I had to add wood trim, top and bottom.
2. The 2x4 frame looks solid but it would actually flex when driving, causing the TV to rattle.
In 2011, I tried Upgrade #2 and installed a 40" LCD TV. It looked much better but small pieces of wood trim were still needed top and bottom.
Upgrade #3 in 2013
I always thought a 50" TV would work in the front of a MH. This year I decided to find out.
To address the flexing issue, I built a new box frame out of 3/4" laminated plywood. I used it successfully in Upgrade #2 with the 40" TV. Here it is, with new holes drilled for the 50" TV:
You can see how some of the cutouts from the 40" TV no longer work. This frame is so rigid and strong, I didn't see any need to worry.
The new box frame is mounted flush with the original TV frame with four stainless steel screws holding it in place:
The new TV is a 50" LED LCD. It fits surprisingly well, extending only 3" below the original frame. Two of the cupboard doors are partially blocked, but frankly, they are rarely used. Most important: None of the viewing angles of the driver or co-pilot are obscured:
So there it is. A 50" TV works very nicely.
There are a couple of advantages with this setup:
1. The LED backlighting is brighter than the previous TVs. This means significantly better daytime performance.
2. This display has better 'off axis viewing' than before. It means you can sit at extreme off-center angles and still see a good image.
3. This is not the thinnest TV I could find. Rather than pick some of the 1" thick alternatives that I have used successfully at home, I chose a TV that would give me room behind for access to the HDMI and composite connectors
Anyways, I hope these pictures help anyone considering a big TV upgrade.
Now I just have to stop thinking how to get a 60" TV to fit.
  • Often wondered if you couldn't have a 'swing up' setup for the TV that would have roll up desk type doors and shelves behind it for book storage. The TV would be latched to the ceiling while traveling.
    Wonder if anyone has done that yet.
  • Holy big TVs Batman. That is huge. Looks nice. You can plug MS Street & Trips into that and have an almost life size scale nav system.
