Naio's avatar
Naio
Explorer II
Jun 07, 2015
Is my Wilson Sleek broken or do i not know how to use it?
This is the one I got used on craigslist.
I drove out to flat farmland, 15 minutes from town. Two bars, no/intermittent data, and 103db without the sleek. Plugged in the sleek and put the antenna on my van roof. Sleek got warm, but still the same 103 db.
In town now, I have 4 bars, full data, and 102db. I am thinking this db business is not the whole story. Or my phone's db meter is broken.
Help? Advice?
(I did not test data while in the sleek; this model sleek is not supposed to work on data. Can't go back, anyway, as first the van needs to go back to the shop. I WAS leaving for a 3 day camping trip, but the steering is still messed u. I decided unsafe and gave up on the trip. Poo.)
  • Naio's avatar
    Naio
    Explorer II
    Maxi Signal wrote:
    Naio wrote:
    GordonThree wrote:
    No db gain, not compatible with the primary band of your phone. If the phone has any signal on its primary band it will ignore other bands despite those being stronger.
    Hmm...
    It does 800/1900mhz and my phone is an Avant on tmobile. Did I google that wrong?
    It does seem like it is doing stuff and my phone is ignoring it.
    Tmobile voice is usually on 1900 mhz. Very rare they use 850mhz. Tmobile data is on 1700/2100 mhz if in a home area if roaming on AT&T network it is on 1900mhz.
    Thanks! I noticed it said 'not roaming'.
    So, the sleek is right for my phone, for voice, yes?
  • Naio wrote:
    Hmm...
  • Naio's avatar
    Naio
    Explorer II
    Hmm...
  • No db gain, not compatible with the primary band of your phone. If the phone has any signal on its primary band it will ignore other bands despite those being stronger.
  • Naio's avatar
    Naio
    Explorer II
    Thanks, folks!
    I didn't know about the distance thing. I had my phone in the cradle. and the antenna on the roof. Maybe 3" away, but the roof IS metal. No poptop or even sunroof.
    Would that cause the db rating to be unchanged in/out of cradle?
    I also had the phone plugged in, it and the sleek in the same double usb jack, cables roughly parallel. Is that bad?
  • RoyB's avatar
    RoyB
    Explorer II
    make sure the WILSON SLEEK you have is for 3G or 4G service that your cell phone needs. The WILSON SLEEK CRADLE comes in both models...
    The WILSON SLEEK cradle is a passive connection to your cell phone when it is placed into the cradle. There is no physical wired connection to the cell phone. I use one here for my VERIZON MIFI WIFI HOT SPOT unit. Definitely works good for me...
    The WILSON SLEEK will give interference if your outside antenna is too close to the cradle. If your vehicle roof is metal that should not be a problem for you.
    I can only get a foot or so away from the WILSON cradle with my cellphone and start losing the relayed amplified signal.
    Using my VERIZON MIFI WIFI HOT SPOT in my vehicle WILSON CRADLE allows us to connect up to five of our WIFI enabled devices while we are moving down the highway.
    When we setup our WILSON SLEEK CRADLE using our VERIZON MIFI unit in our trailer at the campgrounds we get a good 80-100 feet WIFI Signal around the camp site. We can sit outside in the patio area and use our WIFI enabled devices just fine.
    Roy Ken
  • specs call for 6ft of distance between the cradle and the antenna
    because both are transmitting a signal, low power at cradle for the phone, full power at the antenna for the tower, to close together and you have interference issues, the high power boosters have even more critical requirements, like 25ft seperation
    if the phone is in front you want the antenna on the roof at the end of the cable
    if the antenna is in the front you want the sleek cradle in the back of the Van
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
