- ol_Bombero-JCExplorer
Jackfate wrote:
My last TV factory Jack worked well but not my new one . At the last minute I took a small bottle Jack along . Do these plastic drive on things work well? I suppose I could use my wood ramps in a pinch.
Cheers
Plastic Drive = sounds like something at Disneyland!
Harbor Freight 12K Bottle jack
-and-
Any of the several ERS ("Motor Clubs") for when you either don't want to do it yourself of need a tow, or?
The tow company in any given area may contract with several.
The service you get -or wait for- depends on their work load.
often a credit card for your ERS will greatly expedite wait time.
~ - 2012ColemanExplorer II
djgarcia wrote:
Its called Trailer Aid. Made by Camco, Sold by Walmart, Napa Auto Parts, etc.IdaD wrote:
Bottle jack works great and they don't take up much room or cost much.
Camping World sells a device called a "Travel Aide" that you set on the ground and just roll a tire up on and the bad tire is lifted up in the air so you can change the tire without having to use any jacks. - 2oldmanExplorer IIx2 on a bottle jack, and, carrying a compressor in case your spare is (likely) low on air.
- Bob_OlallawaExplorer
ScottG wrote:
I'd rather spend 15 minutes changing it myself than wait 1 or more dangerous hours on the side of the road for some service to show up.
I agree, but boy the big rigs sure make it fun when they pass by close. - Chuck_thehammerExplorer4 way lug wrench.
12 ton bottle jack.
gloves and floor mat.
homemade wedge thing. to try driving up on. before I spend 70 dollars for the plastic one.
if it does not workout.. will become fire wood.:)
YES this place can be a Rough bunch. - ScottGNomadI'd rather spend 15 minutes changing it myself than wait 1 or more dangerous hours on the side of the road for some service to show up.
- Torin 2-stage bottle jack to lift the end of the axle.
Old Craftsman torque wrench to R&R the lugs.
MV-50 12v compressor to top off the pressure in the spare.
Leather work gloves and the door mat. - GordonThreeExplorersingle axle tt here, so the drive on don't work for me.
I use a bottle jack. It takes a LOT of pumping, but not much effort to raise the trailer. 18v impact wrench to spin the lugs off, sometimes a 3ft breaker bar if the rust is thick. Breaker bar handle fits the hole in the jack for pumping, so that's handy. - lhenry8113ExplorerThose "Plastic drive on things" do work well and make things pretty easy assuming you have the other tools. I used mine once and have loaned it out 3-4 times--last time at a gas station where a family with a TT pulled in with a shredded tire, on the trailer. The gas station was in a remote area in B.C. and they wanted $30.00 to change the tire. The husband did it himself in about 20 minutes. Afterwards, he said the that "thing" was a must have and was definitely getting one. Lars
My D.W. and I both have cell phones but they aren't much good when there is no service:B - PawPaw_n_GramExplorer
Just be sure to break the lug nuts free before lifting the tire off the ground. I used to carry a metal ramp to do the same thing. Sold it - took up too much space - bottle jacks are much smaller.
I have two 12 ton bottle jacks. I also use some of my leveling boards to lift the bad tire up until it is just touching the ground enough to hold the tire against the 4-way pressure. The bottle jack for the final inch or so.
I've only used this once on my rig, but at least a dozen times on other folks.
The funniest was the two pretty young college girls at Big Bend NP who needed a tire changed on their Jeep Liberty. They apparently assumed that I would actually do all the work. Firm believer that everyone who drives should be able to change a tire. They learned how to do it that day.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
