Picking up from this
responseJBarca wrote:
So how does any of this relate to mrekim's bent in right side A frame? This side did not bend the snapup yet we have evidence the cam arm rotated enough to cause the frame to bend.
There are a few factors in this equation. Some are these 3. Their may well be more however these 3 come to the top of the list. Anyone with more, please add.
1. A new 2013 1" offset on the cam arm frame plate.
2. An 6" A Frame made from 11 gage tube steel on an 1,100# loaded TW which is very inline for the size of camper.
3. Another factor not yet discussed is hitching up. Mrekim when you hitch up do you flip the snap up's real easy either by your hand or gently pressure on the pipe OR do you pull full weight of the spring bar with the pipe to snap up? What do you do tongue jack during snapping up?
Before I go down the road of no. 1 and 2, need to know how number 3 is performed. Please give us the details on how you snap up?
Mrekim has confirmed no. 3 is not an issue and he uses little effort when snaping up during the hitching process. This now leaves no, 1 and no 2 as possible factors.
This is a "hypothesis" not backed up by the usual evidence however it is at least a possibility. (yet to be proven) Both 1 and 2 contribute together to aggravate the problem.
The combination of the larger 1" offset on the new 2013 upgrade of the DC frame plate creates a slightly large lever effect (increase moment of force) when the WD chain is pulled up hard over the 1/2" or 3/4" of the prior vintages. It in itself is not a large change however we have the thin tube A frame in the middle of the mix. I'll say the somewhat obvious, if the frame cannot resist the bending moment of the side loaded DC, the frame is going to bend. In this case using the original vintage with 1/2" offset may or may not have made a difference. The only point I'm making is, the 1" offset is a larger lever moment. Since we still do not know what all of the chain loads are in all towing conditions, it is hard to tell if this increased lever is a factor or not.
When WD is engaged there is a large downward force on the top of the A frame by snapup. There is also an equal and opposite reaction of force pulling up on the cam arm as tension is applied to the WD bar.
When towing if you bounce over a bump or pot hole, an dynamic impact load goes into the hitch. If you are turning even a small amount the load on one side of the A frame can be higher then the other. The heavier loaded side is pulling up on the cam arm even more.
In this case, if the frame cannot resit this normal action associated with this style DC, something is going to bend. In this case the A frame.
This comes back to high point side loads into thin wall rectangular tubing. Hind site is always 20/20. Adding thicker spreader plates to even out the side loads is for sure a positive step to help prevent this from reoccurring.
Some research on this year/model or others in the same weight class by Coachman may turn up others with a common problem.
Hope this helps
John
