jaycocamprs wrote:
librty02 wrote:
Lynnmor wrote:
While the OP wants to use the truck on flat ground, it should be mentioned that the lawnmower engine will not do a good job holding back if a steep downhill is encountered.
Eh both my 3.5 so called lawn mower engines hold my 7200lb trailer back very well all through the Appalachians in Pa Wv Va and NC usually only tap the brakes twice on the 6 mile 1700ft decent on 77 through the Blue ridge mountains it holds at 55 with no problem whatsoever...if the 2.7 is like the 3.5 in that aspect I don't see an issue...where I see one is possibly the trucks GVWR and wheelbase for that longer trailer.
The 2.7 won't hold the empty truck back. Other that that it's a great truck. I don't see how the 3.5 could do much better. Unless like some of the other Fords, it uses the service brakes.
I have 2 3.5 ecos an 11 and an 18 and they have both held back my 7200lb trailer with extreme ease...not sure where you are getting your info that it won't even hold an empty truck back?!? As I have over 80000 miles towing that 7200lb trailer with both trucks now all through the Appalachians. Have you or do you own a 3.5? If not how can you say what you did?!?!
