Lwiddis wrote:
If you can’t accurately determine the probable weight of your loaded/wet TT you can’t estimate whether or not a particular TV will pull and carry the weight. Further, 1192 pounds of TT cargo capacity stinks. Yes, I’m spoiled....with 3220 pounds. Your truck is rated in a number of ways. You mentioned only max gross trailer weight. What’s its payload? You’ll have around a thousand in tongue weight.
Since our last posts got sent to Internet never never land, let's try again.
How accurately should he determine his weight?
I mean, it ain't going to be 6400lbs and it could be 7600 lbs easily, heck, let's say he has a rock collection and its 8klbs. Who cares....That's like 1600 lbs. Not a huge difference, but when you compare it to at least 7000lbs which the OP should be given credit to at least know he's going to add water, gear, beer and groceries to his camper.
Can you say what makes it apparently unsafe to you for the OP to tow a 3-4 ton camper with a new F150?
Be specific. With your great wisdom and experience that is surely backing up your succinct and definitive assertions, surely, there's something the rest of the world is overlooking when they hook up their similar trailers every day and safely make it to their destinations repeatedly, without issue.
