camper1013's avatar
camper1013
Scale numbers and distribution setup
I am looking for some help/advice on my WDH setup and adjustment.
I went to the scale and these are my numbers:
W/ WDH
Steer:3380
Drive: 3900
Trailer: 6580
W/O WDH
Steer: 3180
Drive : 4200
trailer: 6500
Truck
Steer:3500
Drive: 3140
This was loaded for a 9 day trip.
I have not measured the truck heights, but everything sits pretty level. Just looking at the numbers it seems as though I should adjust more weight onto the steer axle. I have an Equlizer WD. How do I adjust more weight to the front axle? Is this adding another washer or 2? There seems to be a lot of adjustment factors in the hitches and don't want to make things go the wrong way.
I know I am at my limits, but want to make sure things are set up as best they can. I do increase air pressure to help as well.
I used the towing planner chart, and I am right around 10% tongue weight.
For information truck is a 2016 Chevy 1500. GAWL 3950, GVWR 7200. Trailer is a Keystone Passport with GVW 7200.
  • Were it me, I would adjust the hitch to restore the front axle weight to the same as it was before you hitched up. Don't worry about the rear axle of the truck. It will take care of itself.
    By doing that, your headlight aim will be fine and the steering components will be at their normal angles etc. You will probably find that the truck rides a bit better also. Some vehicle manufactures say to only restore 50% but I am one who feels that allows the headlights to aim too high so I use 100%.
    You say you have an Equalizer hitch. Is that the brand name Equal-i-zer or a generic equalizing hitch? If Equal-i-zer, the "L" brackets should be adjusted so the bars are level with the surface they rest on the brackets. You don't want the bars angled upwards because the bars will then only rub on the front edge of the L bracket. Same goes for the bars angled downward. They will then only rub on the rear surface of the L bracket. What you want is for the bars to rub flat on the bracket and adjust for that.
    To adjust the amount of weight transferred to the truck, you tilt the hitch head by adding or subtracting washers. Start with 5 and work your way up from there. In your case, I would add two more and then re-weigh your rig.
    The same adjustment process goes for a normal WD hitch. Once you find the correct chain link to use (usually 5 minimum) you adjust the weight transfer by tilting the hitch head. The reason for the 5 minimum chain links between the snap-ups and bars is to let the bars move back and forth when making turns. Too few links and the chains will crash into the brackets and/or pull the bracket forward or backward on the A frame. Also can bend the brackets if bar pull is strong enough.
    Hope this wordy explanation helps you or someone else a bit. :)
    Barney
  • Here's a link to a calculator that takes all your numbers and tells you where you're at.
    You'll need to get a couple more numbers from your tire / loading sticker and your hitch receiver.
    Another calculator that may help with loading.
