Flapper's avatar
Flapper
Stability, hitch and tongue weight....
Concerned over handling of my combo - but I'm inexperienced as to what "good" travel trailer towing should be like.
Problem: Occasional small sway (measured in a couple of inches each way, but can be felt and visible in the mirrors), that goes away when I slightly reduce speed. Some "suck" by semi's passing. Wind gusts (15-25 mph) require constant two handed steering. 60 mph in the wind was top speed, before I started gripping the wheel harder, or backed off due to the rare small sway events.
Prior towing: 20ft boat, Jayco 30 ft. fifth. Both of which were solid when being towed.
Truck: F-150, SCrew, Eco, Max Tow, HD Payload, LT "E" tires.
Travel Trailer: Grand Design Imagine 2670MK, 32ft.
Hitch: Andersen "No Sway" WDH
Loaded trailer weights: 7,640, 805 tongue with 15 gal water. Tank is midway between tongue and TT wheels.
On return trip, I filled tank completely (30 gal more), so guessing TT was at 7,895 and 930 tongue. Only slightly better.
In the first instance, was able to crank the Andersen to a point where front fenders of truck were back to unloaded height. On second, was able to get them a bit over 50%, which is Ford spec for WDH.
By my math, was at 10.5% tongue originally, increased to 11.8% the second time. Not much to do to further increase the %, unless I start shopping for several big batteries.
With a payload of 2,166, and GVW of 8,200, the truck is better than some F-250's, and already has a pretty good wheelbase - so not thinking it is a truck problem.
So, opinions please - ditch the hitch, and get a ProPride? Buy more batteries for tongue weight? Both? Or suck it up and accept that this is why people say 5th's tow better than TT's?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
