rvhippo's avatar
rvhippo
Towing 33', 7500 GVWR trailer with 1/2 ton truck.
Conclusion: NOT FUN. Do-able, but NOT FUN. Two hands on the wheel at all times.
The Truck
2016 Dodge Ram 1500
5.7L V8 gas engine
8-speed auto transmission, 3.92 final drive
1,630 lbs. payload capacity
10,300 lbs. towing capacity
The Trailer
2016 Jayco 2867 BHSW
33'5" overall length
7500 lbs. GVWR
Equalizer 4-way hitch
*Engine more than capable.
*Transmission probably won't last long. Shift logic already locking into tow/haul mode even without the trailer attached.
*Payload capacity sorely lacking. I put Timbrens on the back and they help a lot. I couldn't imagine towing without some kind of spring/helper in the back. The 1/2 ton is sprung for comfort and any weight immediately maxes out the rear springs.
*I probably will have to adjust the WD hitch when I get more time (combined rig is VERY sensitive to WD hitch adjustments, I'm on my 4th adjustment setting).
*Brakes adequate. ABS kicks in during emergency braking so braking power isn't the limitation.
The rig is very, very sensitive to passing vehicles and crosswinds. Not a problem to keep it within the lane markers, but requires constant small steering corrections if there are passing vehicles or cross winds. Steers straight and true with no sway motion in a straight line.
Not difficult to keep in line, but it requires constant vigilance. Not a relaxing drive, but not scary either.
Have had to make one emergency brake/swerve maneuver when someone cut me off trying to get on the same off ramp at the same time. Truck and trailer tires all squealing. Was able to bring rig back in line at the adjacent lane with no sway.
I would rather have a 3/4 or 1 ton truck, but Chrysler was willing to lease me this truck for $11.50/day. It works, but I couldn't imagine towing anything heavier (or closer to the 10,300 lbs. max tow limit).
  • I believe you need to adjust your hitch. I now tow a 7300 giver TT with my so called 1/2 ton truck. I have no problem what so ever. No sway and passing trucks don't bother it I have a very comfy easy towing ride. Yes I tend to ride with one hand. Now if only I could feel when I lose a tire. All would be great
  • Hopefully this is a temporary thing and you're traveling alone.
  • first mistake is believing the numbers are Real..
    truck numbers are inflated.
    trailer numbers are underinflated.
    you should be using a 2500 already.
    fyi, my trailer has 2 weight tags. both say 7,500 pounds dry/empty..
    my trailer is scaled at 8,300 empty and dry.
    I have a 2012 F 250 and a 30 foot travel trailer.
  • Mfg. published MAX TOW RATING is a magical marketing number using a base model, a 150# driver and 20# cargo.
    One will run out of actual payload capacity long before reaching that magical max tow number and then trucks GVWR.....along with RAWR/Rear Tire Max Load
    This holds true for 1/4 ton, 1/2 ton, 1 Ton etc.
    Not just 1/2 ton.
    All can be a tow vehicle within their REAL ratings/limitations.
    Simple math.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
