BFL13
Nov 28, 2017Explorer II
750mv vs 12v Thermostat Question UPDATE 2
Updated 29 Nov-- Update 2--29 Nov: got it to work.
Not clear on the thermostat voltage for these things whether I can use the cheaper version or what. I want it for my furnace only set-up in the RV that has the two 12v wires going into the back of the existing thermostat that is not working right--bad sensor it seems.
Honeywell tech support says their only model that is for 12v is the CT53K as in this example. It says it is for 750 millivolts
https://www.sylvane.com/honeywell-ct53k1006-millivolt-thermostat.html
However, this economy one looks similar but says it works with 750 millivolt.
http://www.canadiantire.ca/en/pdp/honeywell-economy-linevolt-thermostat-0528505p.html#srp
I will need to add an on/off switch to the 12v line so it won't try to run the furnace when the RV is not being used and it is colder out than the thermostat's temp range goes down to.
What's the story with these things? Thanks.
