BFL13's avatar
BFL13
Explorer II
Feb 11, 2017
950w 2-Stroke Gen Questions Update
Updated 22 Feb
Need a new thread on how to work/maintain the 2-stroke 950w gen
This OP built of some posts from old thread now off topic for that thread.
http://www.kingcanada.com/Files/KCG-950G_manual-eng.pdf
Found this. Adds to the other maintenance advice included here.
It says to ground (Earth ground) it---I never did that and don't with my Honda. Been threads on that topic. I don't plan on grounding it like it says unless folks here say this is different from the Honda for that.
Note about using a surge protector re earlier discussion wrt MSW (not) etc. Does this change anything?
No mention of "breaking in." What do you do different for a break-in period with one of these, and for how long?
Mr Wizard--
"I used to do a lot of 2 stroke honda moped repair, rebuild, hop up etc..
iron cast cylinder with aluminum piston
remove the exhaust, soak in safety solvent, blow out in reverse with compressed air (air in the tail pipe)
but back on the engine and let it run until all the smoke is gone
when first started it will smoke like a fog machine
great way to kill backyard mosquitoes
amisol or other synthetic 2 stroke oil, leaves NO carbon in the cylinder or exhaust
over oiling with cheap oil clogs up everything with carbon
since it is hard to start, even with starting fluid
there are two possible problems
sticky reed valves from fuel varnish
and carbon in the head which absorbs what little fuel is getting through
all depends on how hours of run time, low hours is probably sticky reed valves
lots of hours could be carbon or both "
TomG2--
" Not knowing the hours on the generator leaves open the possibility that it was not or is not broken in properly. Some require up to 25 hours of break in time."
RLS7201-
"You can clean up that smokey King by using Amsoil 100-1 2-cycle oil. I've been using it since 1979 in all my 2-strokes, including my dirt bikes, with no failures. The initial price of a quart is startling but do the math and you'll find it no more expensive than running 32 or 50-1 premix.
Also, when you run less oil through the main jet, you get more gas, which means a slightly richer A/F ratio. That may help with the RPM hunting, lean roll.
In my 175cc dirt bike, I had to reduce the main jet one size when I change from 50-1 to 100-1 premix."
There were others who provided good tips but this will do for now, thanks.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
