AndyfromTucson's avatar
Oct 19, 2016
Advice needed on delamination repair
One sidewall of the cabover of my Class-C had a lot of delamination. The previous owner had apparently replaced the Filon and luan in this area before, so I just took off the edge molding and pried off the Filon and rotten luan, which exposed the styrofoam and 1" aluminum square tubing framing underneath. After doing research online, here is what I have come up with for how to proceed; If you have any experience with something like this please let me know what you think:
- I want to use Azdel instead of luan for the fix because Azdel is synthetic and won't rot, but I have not been able to find a vendor who sells single sheets of it in the thickness I think I need (1/8 inch or 3mm). Any ideas on how to buy Azdel or similar?
- First step would be gluing the old Filon (still in one piece) to new luan (or Azdel if I can find it) using 3M Hi-Strength 90 Spray Adhesive to make a new Filon-luan panel.
- Second step would be screwing the top edge of my new Filon-luan panel to the top aluminum tube of the framing to get the positioning correct.
- Third step would be swinging the new panel out a bit, then getting under it and applying 3M 30NF Contact Adhesive (supposed to work on styrofoam) to the framing and styrofoam and the underside of the new panel, letting them dry per instructions, then pressing them together and using some sort of roller.
- Final, replacing molding with new butyl, etc.
Any thoughts, corrections or advice?
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 23, 2026
