DVGaylin's avatar
DVGaylin
Atwood thermal cut-off issue
This one has me baffled.
I had a spider web nest in the LP blow through tube causing a block. The thermal cut-off link blew as it should.
I cleared the obstruction and removed the thermal cut-off (prior to noting the way it was connected. It has female connectors at both ends; I know, I should have taken pics).
I replaced the thermal cut-off with a new one but it blows the main 15 amp fuse in the coach.
If I by-pass the thermal cut-off with a jumper; all is well, but as soon as I put in that thermal cut-off; the 15 amp fuse blows.
To complicate things, I am not completely sure of the correct way the thermal cut-off should be installed I've tried both ways (using jumpers).
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
