Smitty77's avatar
Smitty77
Balanced Charging X's 4 6V Batteries
As I've recently started a campaign returning to basics on the care and feeding of my soon to be replaces X's 4 L16's - I have a follow up question.
I've confirmed proper wiring to yield parallel/series, with appropriate and good quality cables.
It was the placement of the Magnum Charger and MidNite Controller charge cable feeds that does not match my research on obtaining balanced charging.
Iota has a nice (Diagrams, makes it easy for a back to basics sanity check!) write up on balanced vs non balanced charging.
My current Magnum and MidNite charge feeds are in a 'non balanced' method. However, when I was getting help here and elsewhere on trying to save my battery bank. I took several multi meter voltage readings of the full bank, and the four individual batteries. And noted. less then a tenth variances in the voltage.
Iota does talk about Amps vs Voltage in their diagrams. So please forgive this question. Does practically balanced voltage at each battery while under charge, equate to balanced amps too?
With a bank of 4 6V batteries vs say 6, 8, etc. - what is the recommended 'Best Practices' for obtaining balanced charging?
TIA, and best to all,
Smitty
PS: OK to say reading too much into this, and not to worry about it...
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
