RetiredBob's avatar
RetiredBob
Batteries--Changing from 2x12v to 2x6v
I'm planning on switching out my two original 12-volt batteries to two 6-volt. My question: Currently with the 12v in parallel, there are 3-4 cables hooked to the positive terminals of each battery. With the 6v in series, can I attach the cables to either of the positive terminals? It would be difficult to attach all of them to just the positive of battery #1. If I can attach to both positives, then I would assume I could also attach some to the negative terminal of battery #1, which is connected to the positive terminal of battery #2. Thanks for any responses.
