joraz's avatar
joraz
Bulk-Absorption Charging Voltage
2 Concord 8D (258 AH each)
Freedom 25 Inverter-Charger (130 amp)
Trimetric 2025 Gauge
I'm dry camping and charging my batteries. They were 30% discharged. My Concords call for 14.2-14.4v absorption and 13.2-13.4v float. My charger (20 years old) is set as close to those numbers as I could get at the wet cell cold setting which is supposed to yield 14.4v bulk-absorption and 13.5v float.
I just started my generator (10K) and see that the charger is only putting out 13.5 volts and 47.7 amps. (same after a half hour or so) Shouldn't I be seeing the maximum bulk voltage right now?
While waiting for some input an hour has passed. The charger is now supplying 14.1v, still substantially less than the 14.4 I had expected.
Thanks.
jor
