helperzack's avatar
helperzack
Can I replace the LP Rubber hose myself?
I found that my rubber LP gas hose was crimped and causing problems with water heater, furnace and stove. When I finally tracked down the problem and straightened the hose all was working just fine.
Can I replace that hose myself? It appears to be threaded on both ends.
Are LP gas connectors threaded backwards? Left to tighten and Right to loose? Seems I heard that sometime.
Also, do you use teflon tape on the connectors like a water connection?
Many thanks for help and suggestions.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
