cannesdo's avatar
cannesdo
Dish picture slightly wavy in the front bedroom...
A few weeks ago my living room tv died. It took me a while to find the same model to replace it with and in the meantime I got and old CRT 19" tv from Craigslist. It worked great. When I intalled the replacement tv in the living room I decided to use the smaller tv to troubleshoot the Dish connection in the bedroom as I was going to install a flat-screen on the long thigh-high shelf soon.
Turns out I like the location of the smaller tv up high and thought I'd keep it for a while. I figured out which connection in the cupboard in the bedroom was for the digital antenna and which was connected to the tv in the living room. I have been running the 2nd bedroom tv on antenna all week and the picture is perfect. Once I got the 2nd dish remote programmed I was able to pull up the programming, guide etc...but the picture is -- it's like a tremor, very subtle, the horizontal lines are a bit wavy, like 1/8 to 1/4 inch which is minor but pretty annoying.
I bought a new cables for the connections that aren't in the wall. The good kind of coax -- RG-6? That didn't help. (These run 1.) from the connection to the right of the sat. inputs 1 and 2 behind the receiver to the wall connection (that leads to the bedroom auxiliary connection, i.e. 2nd tv) and 2.)from that bedroom wall connection (coming from the living room) to the 2nd tv.
I pulled the plates off the wall where the undseen coax exits the living room and enters the bedroom and made sure the connections were tight. They were. So...what's next? Replace the connectors? Don't know if I can access these cables from the basement. I sort of doubt it. It's hard to believe they've gone bad down there where nothing gets disturbed. Could the problem be that it's a CRT? Is it harder for the signal to travel on to another tv? Is it like a power cord? Does distance matter? Might it be better with a newer, say...LCD tv?
Thanks much....
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
