- 2oldmanExplorer II
toedtoes wrote:
Got it!
That'd be miss or ms please. :) - red31ExplorerA RM2193 compact fridge uses 635 BTU on HIGH and 293 on LOW, a candle is much less as I suspect is a oven pilot in a non windy environment.
https://www.scamptrailers.com/images/pdfs/Dometic_Refrig_RM2193_PartsList.pdf - MEXICOWANDERERExplorerYup and THAT is what my hot water heater has.
The one wide out in the open. Rain and wind...
I would have to guesstimate the pot is still a third full. Sometimes reality jumps in and screws with the best of theories. The stove I spoke of was another Mexican special. We won't talk about the 1,000,000 PPM total dissolved solids the domestic water has. - DrewEExplorer III
Mont G&J wrote:
The answer to the OP's question.
How much gas does a standing pilot use?
Again, this goes back to the design of the burner. A thermocouple system uses about 700 btu's per hour while a thermopile system about 1500 btu's. I find it easier to understand volume in gallons; a gallon of LP gas contains roughly 91,500 btu's. A thermopile assisted burner therefore uses one gallon of gas in 61 hours, or nearly 12 gallons a month. A thermocouple system would be roughly half that amount.
Your oven pilot uses the thermocouple design.
My RV oven pilot uses neither design, actually. It's a standard two-stage sort of pilot. When no heat is being called for, it just runs with a teeny tiny flame. When heat is called for, the pilot is enlarged (more gas is fed to it) and it grows to envelope and heat the bulb of a thermostatic safety valve. - Old-BiscuitExplorer III
Pretty close to what 'Soundguy' posted on 1st page - toedtoesExplorer III
2oldman wrote:
MEXICOWANDERER wrote:
Mr Toes' rig is over 40 years old.
THEY SELL NEW APPLIANCES WITH ELECTRONIC IGNITION
Yep. My rig turned 43 last October. And my fridge and stove/oven are definitely that old as they are original. My water heater may be slightly younger but still well over 20 years old. - Mont_G_JExplorerThe answer to the OP's question.
Your oven pilot uses the thermocouple design. - fj12ryderExplorer III
Almot wrote:
Yep, had to do that with my new toyhauler. They must not have checked south of the border before they installed my stove and oven.MEXICOWANDERER wrote:
They don't always install modern appliances in new RV.
2018 trailers are still being equipped with propane range/oven with piezo-ignitor - that ignites ONLY the top burners, not the oven. You know, rotating knob that goes click-click-click.... nothing.
Owners have to retrofit it with electronic ignition that works better, and install the sparky thingy at the oven pilot as well. - AlmotExplorer III
Owners have to retrofit it with electronic ignition that works better, and install the sparky thingy at the oven pilot as well. - MEXICOWANDERERExplorerWait.
I'll run outside and yell at my 20 lb pot.
YOU CAN'T POSSIBLY RUN FOR 23 DAYS FIRING A 15 GALLON HOT WATER HEATER SET TO 122F. DELTA T 62F
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
